Alright If I have a mono block that is 1 ohm stable and puts out 1500 watts x 1 channel rating. and I purchase a sub woofer that is a dual 1 ohm sub how do I wire it 1 ohm load and would it be seeing 750 watts a voice coil.
By the way the mono block has 2 sets of speaker terminals so 2 positives and 2 negatives.
Would I take a wire from the positive terminal on one voice coil to a positve speaker terminal on the amp and then the negative from the same voice coil to the negative on the amp. And then do the other voice coil the same way to the other set of speaker terminals.
I know I worded this really bad hopefully you understand what Im talking about. Also will this mean each voice coil is getting 750
