Question about running a Dual Battery System...
That makes no sense, there seems to be a HUGE misconception around here as to what is a fully charged battery and I'll bet 2/3's dont even own a voltmeter to make this accessment.
Any time you add a second battery you should charge them with a battery charger first so you know your starting point. Check voltage of the batteries 30 minutes after you finish charging with a battery charger, write that number down. Drive your car for a week or two, wait 30 minutes after you shut off your car, check voltage again. You'll see how little loss you really have with a stock ALT under normal music listening conditions. A Larger ALT is a good thing, for some reason folks think the second battery is a terrible strain for any electrical system, its more of a cushion then anything.........and an isolator is a waste for the majority of audio folks
So if you have a huge system, with 550 amps of max current draw(with (2) 275 amp HO Alts), as well as 2 of these Stinger batteries, and you plan to hardly ever playing your system without your car running (so your car is always running when your thumpin), do you need a(n) relay/isolator?
Notice: 500 amps from alt, 550 total max draw, hence the 2nd battery.
Nope, no point in having it
If you want the ability to have the rear battery just for the stereo so you can jam with the car off - an isolator is for you. If you would rather have double the reserve capacity for the entire electrical system - an isolator is not for you.
With the second option you can jam twice as long with the car off though too
Mr. Black
Mr. Black
Alberta, Canada
qtipextra
BP1Fanatic
BP1Fanatic
