Hi,
I have a Rockford Fosgate P1000-1bd which is 1-ohm stable @ 1000w, 2-ohm @ 500w, 4-ohm @ 250w.
The sub is currently running 2 KFCW3011 SVC 4ohm wired for (I believe) 2ohm load, so the amp RMS (500) is below the 2 subs' RMS (~800).
My question is regarding what I should do since I'm downsizing from 2 subs to 1 sub to regain trunkspace. I was looking at the Rockford Fosgate P3D2-12 or P3D4-12 -- the only difference between them being that they're 2ohm or 4ohm (both DVC). Should I go with the P3D4-12 and wire for 2ohm load, effectively making it the same as my current setup? Or should I go with the P3D2-12 and wire for 1ohm load?
My greatest concern with going with 2ohm @ 1ohm load is that the RMS of the amp will fry the coil of the sub since it's only 600w RMS/1200 peak (if I turn it up too much). Am I going to lose a ton of power by running the 4ohm sub @ 2ohm load @ 500w?
Thanks for your help in advance.
I am also open to recommendations for this wattage if you have them. I can't change the amp, but I can change the sub I buy. Willing to go to 10" for even more trunk space if anyone thinks I can get the same oomf and accuracy as I do currently. I run a sealed box, and plan to do the same with the sub I buy next.
