Question about my RE MX
NeedDirections
alligator toilet seats
So I just installed a 12" RE MX into my car.
After cutting my box (mx is indeed 13" and did not fit) I wired it up, but I wasn't really sure how to wire it to 1 ohm (sub is D2) and the guy at the shop who cut my box got out his RE installation manual and said we did it right...
Fast forward to installing the sub. It's running off a planet audio vx2200D (2250 rms at 1 ohm) and my electrical consists of a yellow top starter and a stinger spv-44 in the back.
Basically the sub just doesnt hit that hard. it moves air and gets low but its not much (if any) louder than my Diamond audio tdx 12" off 1200w...
My voltage drops into the 11s at full crank
HPF and LPF are set correctly
I don't have the big 3 done yet because I don't know how.
Thanks,
Phil
You have the positive wire on each coil wired directly to the positive output on the amp, and the negative wire on each coil wired directly to the negative output on the amp, correct?
You did not tell us what box the sub is installed in.
Is that the same box the old sub was in?
Brian
Is that box designed for that sub? You can't just throw any sub into any box and expect it to sound good.
You sub should be wired like this:
Re recommended specs are 2.2 @34
my box is 2.5 @35.
I am going to pull the sub and check the wiring today after class.
ed: the sub moves air and gets loud, just not even close to as loud as i expected. also sub doesn not get hot at all.
NeedDirections
NeedDirections
Tampa, Florida
NeedDirections
