question about my amp
every1 hates me
dont hate...lol my amp is an american legacy 2000 watt 2 channel
its model number is LA2060
LA2060Two Channel Amplification 1000 Watts x 2 Output 2000 Watts x 1 Bridged Output Fully Adjustable Electronic Crossover Network Variable Bass Boost (0~12dB @ 60Hz) Soft Turn On/Off Circuit 2 Ohm Stereo Stable Bridgeable into 4 Ohms MOSFET PWM Power Supply Heavy Duty Aluminum Alloy Heatsink Discreet Wire Connections Variable Gain Control Remote Turn On/Off Hi/Lo Level Inputs Gold Plated High Impedance Input High Level MOLEX Input Power On LED Indicator LED Protection Indicator S/N Ratio: >95dB • THD:
thats the specs and shit on it
i was just wondering if i would be able to hook my my 2 pionner subs (120rms 400 max
4ohm) parallel cause i read sumthing sumwhre that if u hook up ur subs parallel and the amp isnt designed for it ull destroy the amp and itll be garbage...so i was just wondering if i would be able to hook up my subs parallel to this amp or would i be better off with the series hookup?
thx in advance
It all depends on the voice coil configuration on the subs, are they DVC, SVC, 4 ohm, 2 ohm?
Also, your amp is probably only 4 ohm stable in bridged mode, so if you create a lower load than that when wiring the subs, your amp will most likely fry.
specs on the subs
Pioneer TS-W28C 400 Watts 10" Subwoofer.10" Subwoofer features 4-Layer Copper Voice Coil, 90 dB Sensitivity and 400 Watts Max. Power.450 Watt Max Power IMPP Composite Cone 4-Layer Copper Voice Coil Vented Pole Yoke Sensitivity: 90dB Frequency Response: 20-4500Hz Sealed/Ported/Bandpass Enclosure Recommended Enclosure: 1.0cu ft
You just gave me every spec except the one that I need;)
How many voice coils are on each sub? And what is the impedance of them?
Originally posted by snova031 You just gave me every spec except the one that I need;)
my book that came with it says nominal impedance - 4 ohms
and it says 4 layer long voice coil design
im still kinda new at car audio so go easy on me heh
look at ur subwoofer and look where u hook up the speaker wire. on one of the subwoofers is there a spot to hook up 2 the positives or just one? that is about as simple as it gets
then u have two 4 ohm svc subs. well if i were u i would hook up those up in series. there is probaly a diagram round here somehwere to look at. that will probaly give u somewhere round 400-600 rms so u just need to turn down the gain all the way and just work ur way up till u get what u need. hope that helps
Originally posted by jbl_marshall21 then u have two 4 ohm svc subs. well if i were u i would hook up those up in series. there is probaly a diagram round here somehwere to look at. that will probaly give u somewhere round 400-600 rms so u just need to turn down the gain all the way and just work ur way up till u get what u need. hope that helps
His amp will fry if he does this.
Wire each sub to its own channel, thats the only way you can do it.
every1 hates me
every1 hates me
New Jersey
every1 hates me
vegang
vegang
