Question about Mtx 1501d amplifier
berettagtz
I was wondering if this amp would work at 1.5 ohms.
Here are some more specs about it:
THUNDER1501D
• RMS Power measured at 12.5 Volts DC:
500 Watts x 1 into a 4 Ohm load with less than 2% Thd+N
1000 Watts x 1 into a 2 Ohm load with less than 2% Thd+N
• Dynamic Power measured at 14.4 Volts DC:
750 Watts x 1 into a 4 Ohm load
1500 Watts x 1 into a 2 Ohm load
• Signal to Noise Ratio: ≥100dB A-Weighted
• Damping Factor: >100
• Frequency Response: 20Hz-200Hz ± 3dB
• Maximum Input: 8Vrms
• Thunder EQ: Variable Bass Boost (0-18dB) centered at 40Hz
• Crossover: Variable 40Hz to 200Hz, 24dB/Octave Low Pass
• Dimensions: 17.8" x 9.75" x 2.1" (45.3cm x 24.8cm x 5.3cm)
i have amodded one running at 1 ohm and it runs fine, gets a lil warm but only gets HOT if i run it harder than hell for over 30 min.....solid amp. 1.5 ohms on a modded one will do just fine....
berettagtz
berettagtz
nashville, tn
iagrdshaka
