ohms
Ohm's Law...
Generally, most amps produce less power at a higher load impedance (ideally, halving output power every time you double impedance). Less power = less current = less strain on your electrical system.
I say generally because there are exceptions, like the JL Slash series or the PG Tantrum & Xenon series.
^^ Correct. It's the power drawn by the amp that strains your electrical system.
Some amps are more efficient driving higher ohm loads, which means there could be an advantage to 4 ohms v.s. 1 ohm, but that's totally dependant on the amp design.
Smac
I need $
Smac
Iowa
maylar
