Question about audacity
I don't want to get into changing the song. I just want to view a certain frequency range to see where the peaks are.
Exactly. High-pass it and low-pass it like I said, then use the Plot Spectrum tool. After you find the frequency, all you have to do is exit out of Audacity without saving over the song (or just undo twice)
Did you try switching the Frequency Analysis Algorithm to Spectrum, Size to 4096 or higher, and Axis to Log frequency? Granted, you must select a small sample of music data prior to doing this.
If that is not enough for you, you could always export your results to a text file and rebuild your graph in a spreadsheet.
Buck
little alien on campus
Buck
Inside of a pyramid
gunz4me2
vegang
vegang
