Question about amp
mabel4life
Frank the Tank
I am looking into buying 2 TC db-500's and looking for an amp to push them. TC's website recommends between 200-1000 rms per sub at 4 ohms. I was looking for a budget amp (150 or less) to push them. I looked into mainly profile and crunch. I came across the Crunch PZI325.2. specs are as follows:
300W x 2-Ch @ 4-Ohms or
600W x 2-Ch @ 2-Ohms or
1200W x 1-Ch @ 4-Ohms
I was wondering if I bridge the amp at 4 ohms would each sub get 1200 watts or 600? I really don't know much about amps and this stuff so I was wondering if someone could help me. If this isn't a good amp then what would be a good one for these subs (keep in mind $150 budget). Thanks.
if u wire both together u cant use the 1200x1 @ 4ohms. Cuse wired together u can either get 8 ohms or 2. U best option would be just running each one at 300rms w/ that amp or get a better amp.
If I were to wire the subs to 2 ohms would i get a mono amp then? How does that work?
Edit: What about a Lanzar Vibe266?
•2 x 500 RMS at 4 OHMS
•2 x 1000W MAX at 4 OHMS
•1 x 2000W MAX at 4 OHMS Bridged
If I would get this would it be too much for my alt and battery to take? I havent upgraded my alt or done the big three.
mabel4life
Frank the Tank
mabel4life
central PA
mabel4life
Mike Mccabe
