Question about adding second amp
darkhunter139
Im thinking about adding a second amp to power my speakers, would I have to run another power line?
Also I have a 500 watt amp already hooked up and would probably get a 4 channel 500 or so watt amp for the second. Would this be too much power for only having one battery?
lol
come on bro why would you run 8 gauge?
i wont run anything smaller than 4 gauge so take the 8 gauge out and run 4 gauge and get a fused distro block,and use the 8 gauge and cut it in 2 or 3 ft strips to use from the distro block to the amp.
lol
What if I want to run it inside the car instead of the trunk could I just attack a 4 gauge to the battery and have to power wires hooked up to the + of the battery?
Ok last question and I know its probably been asked a million times but the search here brings up so many things I could not find the answer.
Is it worth adding an amp on to power my speakers? Will it make them sound a lot better and louder?
Ok well I decided I am going to get an alpine 40 watt x 4 channel amp so that will only be an extra 160 watts RMS (my other amp is probably running at less then 250 too because my sub is only 250 watts RMS)
Would 8 gauge still not be enough to split?
If not I guess I will just get a distro block and some 4 gauge and run it to the trunk. Doesnt make sense to run another wire.
darkhunter139
darkhunter139
PA
darkhunter139
