question about 4 channel amp for components and coaxial.
  • 2
mrpep
chicago
So I have this old earthquake amp tremor TNT600 which is about 75rms if I had to guess, I cant find specs on it. anyway, I have component infinity pr6500cs and coaxial for the rear doors are infinity pr6502IS. The components are 320 watts peak so about 80rms and the coaxial are 60rms. I think this amp might do a decent job of handling them but I do have one concern. The amp has 4 RCA inputs 2 are for low pass and 2 are for hi pass. Low pass is normally for subs and Im not trying to get much bass out of these 6.5 speakers I really want mids and highs. How do I set this up? How would you do it? Hope Ii make sense...
English please? lol.... also, they say 3 ohms for speakers on crutchfield specs and the amp doesnt state ohms so I assume 4ohms for amp ... how do I handle this ?
Just wire the speakers as normal. 3 ohms just means the coil impedance in which the speakers are. Which will get you a little more power from the amp. Anyway the crossover settings on the amp should have a switch for l/p or low pass. H/p. high pass. Or full for full pass. Set to hp or full not lp
Ok, so the amp says "HI-PASS or Flat" and the other side says "LOW-PASS or Flat" so choose flat over low? then hi pass over flat?
You cannot unless you wire the two speakers in series. If you wire them in parallel, that brings the load down to 2 from the speaker and the...
My son is wanting to add a 4-channel amp to power his door speakers in his truck. He already has a Kicker mono sub amp installed and it has RCA...
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
448
mrpep
mrpep
chicago
mylows10
