quantum audio??
there was a few differnt versions of that amp and i have install all of them. first that amp was part of the Q series and had a different heatsink with the 4x20 amp fuses. then the next yr it was rated to do 1ohm mono with 4 x25amp fuses. then it went to the amp you have now. check ur impendence first and make sure it isnt below 1ohm.
check the coils with a dmm then subtract the resistence in the dmm leads.
just make sure you are running 4gauge power and ground, this a a class a/b amp. now when it is pushed hard it will get pretty warm that is fine it a a/b amp. use NO bass boost and set ur gain properly and you will be fine for yrs of bumpage.
there was a few differnt versions of that amp and i have install all of them. first that amp was part of the Q series and had a different heatsink with the 4x20 amp fuses. then the next yr it was rated to do 1ohm mono with 4 x25amp fuses. then it went to the amp you have now. check ur impendence first and make sure it isnt below 1ohm.check the coils with a dmm then subtract the resistence in the dmm leads.
But the one I have has 4x20amp fuses
MTX520
LoUd & LoW iS dA ****
MTX520
Az
infamous_e46
