I mean one amp for both, but thats the wattage i want to send to each sub, i just tried avoiding alot of numbers in the post with saying 1200-1600 rms, hopefully that clears up and ill go check it out. and also i will be running a 2 ohm finalCrescendo symphony 1500, did you want a single amp for each sub or for both as i do not fully understand what you mean by seperate.
Sent from my Z970 using Tapatalk
The symphony wont do 1200-1600 on 2 ohms, but of thats what you need on a budget the brx should do you good.I mean one amp for both, but thats the wattage i want to send to each sub, i just tried avoiding alot of numbers in the post with saying 1200-1600 rms, hopefully that clears up and ill go check it out. and also i will be running a 2 ohm final
They are sitting in a cart now, gotta go cash in my check then orderdid you already by the 2 d2 subs?
sad i looked and it seemed nice, but i just wanna feel more "trusting" of the ampThe symphony wont do 1200-1600 on 2 ohms, but of thats what you need on a budget the brx should do you good.
well remove from cart, and put d4s in the cart. going to make your life easier and cheaper. you can get that hifonics and turn your gain down. rather than getting an amp hand turn your gain up as much a possible.They are sitting in a cart now, gotta go cash in my check then order
---------- Post added at 03:16 PM ---------- Previous post was at 03:15 PM ----------
well its up in the air //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif ill message that guy but still feel free to feed the thread with ideaswell remove from cart, and put d4s in the cart. going to make your life easier and cheaper. you can get that hifonics and turn your gain down. rather than getting an amp hand turn your gain up as much a possible.
but that jbl boomsday has is forsure a beast and would power those d4s nicely although as stated before, its better to get d4s and wire down to 1 ohm. easier to find amps that way
The qubed 2200 was going to be my first recommendation too but he doesn't wanna spend over 300. personally if I was him I'd go with the 2200, just depends if he wants to spend the extra $$Id get D4s and a used sq2200 and just have your gain turned down to around 1500rms that way you dont need to do electrical upgrades. And the anp stays happy because an amp that is turned down ans not stressed is a long lasting happy amp. Every car is different though so ypull have to actually get it and see what your voltage drop is. Hell you mught be lucky and have so little that you can turn your gain up and give those puppies 1k each
