Quad 1ohm
Neither one of those options work for you. Your best bet is to try them strapped at 1 ohm and back off on the gain to keep current draw and output down. They may not like this, depending on the amps though.
If you only use two coils per amp, your options are .5 and 2 ohms.
im using 2 cadence zrs10s. not sure if they will do 1ohm strapped.
if i math the gains on the amps wouldnt i be able to run each at 1 ohm to the sub? so 2 amps running at 1ohm each to the same sub
bones22
bones22
in my house
joetama
