pyle 3000 2 ch amp???
Detailed item info
Product Identifiers
Brand Pyle
Model PLA2230
MPN PLA2230
UPC 68888880282
Key Features
Amplifier Type Dual Channel
Channels 2 Channel
Input Voltage 10.5 volt
Bridgeable Bridgable
RMS Power at 2 Ohms 3000 W x 2
RMS Power at 4 Ohms 1500 W x 2
Performance
Frequency Response 15 Hz - 30 Hz
Signal to Noise Ratio 95 dB
THD at Rated RMS Power 0.04 %
Crossover / Equalizer
Bass Boost With Bass Boost
High - Pass Frequency 40 Hz - 250 Hz
Low - Pass Frequency 40 Hz - 250 Hz
Technical Features
MOSFET Circuitry Yes
Dimensions
Width 17 in.
Depth 10.63 in.
Height 1.42 in.
anyway a good way to make a decent guess is by the total amps of the fuses it has
Say it has 2 - 20 amp fuses on it
that amp most likely is no more than 65% effencient
so 40 (amps) x 12 (volts) = 480 (watts) x 65% = 312 max watts
So what fuses does it have?
Um no this is not the answer
Key Features
Channels 2 Channel
come on 3,000 watts a channel at 2 ohms at 10.5 volts
Everyone on this board would get rid of their amps and run Plye - at least I know I would
so 12 x 80 = 960 watts x 65% = 624 max watts
I would estimate it at around 225 watts per channel RMS
you could use a Multi-Meter and find out for sure if you want.
The thing is about those lower end amps is that they clip hard and easily destroy voice coils
LA951
LA951
Floresville, Texas, United States
assassin1840
BP1Fanatic
BP1Fanatic
