Pushing IN on a subs cone..
boomzabit
Just by pushing the subs cone, how can you tell if its blown? If it goes in and doesnt come back out? If it makes noise when pushing it?
Just picked up a old school L7 12 and i think it might be cooked. Ill find out for sure tomorrow though.
Well if you push directly in the middle of the cone, then more times than not, if it makes a scratching noise, it is blown. But like Chemmins said, you can easily push on it unevenly or not in the middle.
do a battery test touch the wires to the positive and the negative coil of a batt. if you push the sub in and it stays down out of the box It's blown and a sub fails 2 way thermal or mechanical or both. reading the coils isn't always accurate neither.
how to tell if the coils are shot
step 1, remove the dustcap
step 2, turn on sub at a high vol with lots of bassboost
step 3, **** on the sub
now if you get a zap or burn ur tool off then atlease one of the coils is working. if no zap then its garbage.
methode above is only if you dont have a dmm at home //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
boomzabit
boomzabit
Minnesota
infamous_e46
