pulsating sub
CamaroMan42069
NJ
Hey im new to this site, I have installed at least 10 sound systems (head unit, speakers, and subs) in cars for friends and family. But i recently took a system out of my old car and tried installing it in the camaro i just got its a 92. I have dealt with the wining in other peoples systems and fixed it but my system is doing something i have not previously dealt with and i cannot figure out the problem. Every time i turn the radio on i get a pulsing thump not just when i first turn it on but the entire time its on and it speeds up and slows down depending on the volume of the radio. I have tried it with 3 different amps and 3 different sub setups also 3 different sets of wiring in different spots in the car but i still get the same thing every time. I know all of the equiptment works because its all stuff i was previously using in a different car. the only thing thats different is the head unit which came with the car but that is new so i dont see how that could be the problem. it also sometimes makes a weird almost like a squeeling noise similar to the sound a record makes when you move the needle on it. Any help would be GREATLY appreciated.
check all your grounds. chances are the problem is a bad/loose ground on the amp/amps.
ive completely disconnected the entire system (minus the head unit) and rewired it 3 times in 3 different locations still does the same thing.
I had a similiar problem in my camaro, it's a 91. I ended up using the ground under the rear plastics for the hatch pull down motor. I just sanded the paint down and used a good ring terminal. Haven't had a hum in over a year now.
i actually originally had it grounded there but i didnt sand it down first. ill have to try that
did you have the same thumping sound too? or just the weird noise?
It was a nasty low frequency hum that changed volume with the radio. As soon as I turned it on I knew what it was. I originally had it grounded to where the strap for the T-Top bag goes. Changed to the factory ground for the motor and it's been quiet ever since. If it helps I run a kenwood deck, but try the ground before condemning your head unit.
i tried running them on opposite sides of the car it didnt help
Make sure they are not too close to the power wire near the amp. I ran my RCA's and power seperatly as well, but I ended up having the RCA's too close to the power near the amp (extra wire too close) and that did it. Took forever to figure out.
thanks Kiliam i sanded down the hatch motor ground like you said and used a slightly larger gauge wire and its working perfectly now
thanks for all the help guys ill definately be using these forums frequently
CamaroMan42069
CamaroMan42069
NJ
nawgee
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
