Ps2 passcode help!
geardownson
5
NC
I bought a ps2 off someone on ebay an the parental lock code is on an i dont know how to reset it.//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif Anyone know? is there a master code? I cant play any r rated movies till i figure this out //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif Thank you all
Turn off parental lock
Insert a DVD. When the movie starts, press Select to go to the menu. Find the "Setup" icon and select it. When in the setup menu, press Right(2) to get to the custom setup. Go down to "Parental Control" and press Right to go to "Region", then go down to go to "Level". You can now turn the parental control on or off, and/or change the password.
Change or delete parental lock
Press Start when prompted to enter the code. Once you get to where you enter the numbers, press Start and you will be asked if you want to delete it. You can also enter another code instead of deleting it. The master code is 7444. Enter it, and at the last "4", press Select at the same time. Do this again, and you will eventually get the option to delete the lock. Enter 7444 again to delete the code.
Thats a good tip. My cousin set a parental lock by accident, so i'll let him know. Thanks for that.
geardownson
geardownson
NC
SAG3
