winkychevelle
line drivers are generally used to boost voltage on the long runs of the rcas this raise in voltage can block external electrical noise from entering through the un-shielded rcas. this rise in voltage also allows you to keep the gains down on the amp but this doesnt mean the amp wont have to work as hard to make the same wattage. most people think that lower gains mean lower distortion rates but this is dependent on matching the gain to the input voltage on the amp. this is were overhead comes in handyLine driver question:
I have read that one use of a line driver is to boost signal thereby not making it necessary to increase the gains to the point of introducing additional noise. I am looking at miniDSP's which are reported to have low voltage output and so I am considering using a line driver if it will mean less distortion.
Assuming this is true, how is this possible? If a line driver boosts the voltage wouldn't that make it an amp? and wouldn't it introduce noise that would get amplified resulting in no net change?
It just seems that a line driver will also "drive" existing noise as well, introduce its own noise, and submit the final product for further amplification... thereby invalidating its implementation as a means to use less gain and get less noise. Or to say it differently its a pre-gain gain. Is not all gain created equal, or are line drivers a lesser of gain evils?
Thank you
say u have an amp that makes 1000w for an input voltage of 4v at 1%thd if you needed say 750w you might only need to give this amp 3v input and recieve .75%thd due to the amp only pushing 3/4 of its possible power this is all theoretic though. the only way to know 100% for sure is to test and test and test some more.
though boosting the rca voltage with in the range of the amps handling can rejest external noise which would be better for sq. hope this answers your question
