Proper Way to Wire 2 Batteries in Trunk *PIC*
bumpintrunk
Is this the best way right here
Why wouldn't u link the first battery run to the second battery so they all have 2 runs?? don't u want the last one???
the batteries are wired in parallel thats why, and i runing 2 runs of 0 gauge btw because i'm running 2 Orion 2500d's
You only need 1 run of 0 to the trunk, unless you are going to draw ~300A+
Ground your batteries in the trunk and hook the amps directly to your batteries as pictured.
No...
Grounding to the batteries is better than grounding it to the trunk.
And OP: If you plan on keeping these batteries close, there's been a flurry of copper bars on the forum for pretty cheap. You should snatch two or four. FOR TEH UBARNESS.
No...Grounding to the batteries is better than grounding it to the trunk.
Yea but i would hate to run another 2 runs of 0 gauge, and whats the advantage of copper bars vs. 0 gauge wringing?
bumpintrunk
bumpintrunk
Back in MI
01 S 10
