yeah dude i dont know exactly where it is tuned we just started with a base line then we started tweaking until it was the loudest. my truck is the loudest at 30hzHey my friend. Although still tuned low ya need to check ya tuning. I ran it by winisd and depending on the length between 16 and 18 it is 30hz tuning and 31.5. Winisd doesn't account for aero but last time I checked that raises the tuning a hair from playing with bassbox a while back. Although still low tuning not in the 20's. I wasn't posting to put it down at all still very impressive score. Just didn't want people to be mislead
unless you have a super duper uber flare on your aero port....winisd will work just fine in calculating.WINISD is useless when trying to figure aero ports. I have yet to find any online calculator or program that properly models an enclosure that uses aero ports. We just tweaked the port length until we got the loudest score and we ended up peaking at 30Hz. 99% of the time, the tuning is going to be somewhere below the frequency that the enclosure peaks at. Thats why we are guessing that is is tuned somewhere in the high 20s. We are not trying to mislead anyone. We don't realy care what it is tuned at, we just care where it peaks at.
you dont even need to calculate the flare in order to be in the ball park of the tuning by a VERY small margin...
put in volume of the box, and length of the port and how many (after selecting the round port option), and bingo, you have a very very very close calculation of your tuning.
well, i think the two of you (hell, even me) are misunderstanding each other.On paper, or in a program, it might be tuned at 30, but if you had straight 6" ports or a slot port with the same surface area, it will peak at a completely different frequency. The only way to tune aero ports is with a termlab and time. This is just from my personal experience.
yeah most of the time. One problem you realize though. Reality notes typically peak a LOT lower than peak output of the box. For example my explorer peaked at 50hz spl and sounded loudest around there. Reality was 42hz. My friend is tuned 39hz in his wall and peaks at 34hz for his reality noteWINISD is useless when trying to figure aero ports. I have yet to find any online calculator or program that properly models an enclosure that uses aero ports. We just tweaked the port length until we got the loudest score and we ended up peaking at 30Hz. 99% of the time, the tuning is going to be somewhere below the frequency that the enclosure peaks at. Thats why we are guessing that is is tuned somewhere in the high 20s. We are not trying to mislead anyone. We don't realy care what it is tuned at, we just care where it peaks at.
I gotcha. I guess I should have said that WINISD is useless in trying to figure out how the box will perform in the cabin of a vehicle. I just have much better luck with the trial and error method. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifwell, i think the two of you (hell, even me) are misunderstanding each other.
he is just talking about the box tuning. ie: 7.5^3ft tuned to 32hz (or whatever)
you are talking about how the box reacts inside the vehicle.
if you are saying winisd is worthless for its graphs and figuring out how a box will react, i agree. if you are saying you cant use winisd to figure out the box tuning from the get go, i disagree. seems there is a misunderstanding between all three of us what each one is saying //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
thats what i was thinking you were getting at after your last post //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifI gotcha. I guess I should have said that WINISD is useless in trying to figure out how the box will perform in the cabin of a vehicle. I just have much better luck with the trial and error method. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
