project pimpedout97: 4 15" mts walled off
anyways its for 4 15" mts, and as of now, the plan is 4 of the sundown audio 1500w amps (@ .5 on 16 volts) so itll deff be more than 1500w. im also reconing all 4 mts from dvc 2 ohm to dvc 1 ohm (one is a 12, needed a recone anyways, the other 15 has a slight hole in the surround, and the other 15, the basket is bent, so i might as well recone all 4 to dual 1's....btw i had a lil fun with the 12....involved a wall socket lol)
Ah, looks liek you beat me to my new setup.... Only I'm gonna have 3,000 watts on each....If I don't run it at 17 volt //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
Oops, thats right.
Not sure what I was thinking there. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Silly tommy...Those sundownz might Fry with a .25 ohm load daily. I think I remember a kid running into problems with a .35 load daily. Also you might want to check with sundown about running them at .5 daily on 16 volts...just to make sure you are in the clear. Other than that, it should get loud, but it will be all in the build, walls take some engineering.
pimp will lead you on the right path...nothing to worry about //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Silly me, trix is for kids!
dual 2 subs = 1.4/coildual 1 subs = .7/coil
i hope //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
thats a fi philosophy....not always the case.
and
idk what vj said in the first post, but they arent going to be straped at all. according to Jacob, they will lose power if you strap them. they will be running at .5 each, and gain matched to each other.
pimpedout97x
Tampa, FL
pimpedout97x
