Project log+ Lots of pics - 56K slowdown. 15 inch Uberwoofer in a 13 inch tall box.
Does it move a lot with that 600 wts?? What have you had in the past to compare it to???
Box design is sick also!! Good work definately.
V.
ive had 2 se 12's getting 1200 watts, and they were louder to the mic @ 48HZ, but i bet they were nowhere near as loud as this @30 HZ. they were i think 132 @ 30HZ, but i havent had this metered yet
it moves a decent amount, more than ive seen anything else move....and thanks for the compliments on the design
please tell me you will be giving it more power in the future -_-
bondo is an art. so good luck with it. its so much eaiser to just do it and learn than to try all sorts of crap that people suggest. you will get the hang of it.
if you plan on painting this, i'd recommend inversting in some spot putty made by Bondo. Bondo often gets tiny pin holes caused by air, and when you sand them away, another one shows up. Even if you use a good sealer/filler primer, it's still helpful to have. once again, excellent work.
ive seen the carpet pics.
looks shweet.
in fact. why dont you take a peep //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
looks good. but personally id of filled in the area between the baffle ring and the box for a smoother transition //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
iamamp3pimp
Bass Heads Entertainment
iamamp3pimp
Tampa FL
iamamp3pimp
