Project Build for dan69372. Dual 12 enclosure 4.3 cubic feet @ 32 HZ Pics
=[(32-1.5)*(14.5-1.5)*(22.25-1.5)]/1728
=4.76 ft^3 internal volume not factoring in port displacement
=(13*4*25)/1728
=0.75 ft^3 port volume
=[(13*0.75*25)/1728]*2
=0.28 ft^3 displacement of MDF used to make the port
=4.76-0.72-0.27-0.16 (0.16 is driver disp. estimate)
=3.57 ft^3 net volume after all displacements
Plug that into WinISD and it says 36Hz tuning.
The only reason I noticed is the dimensions are nearly the same as this box:
http://img10.imageshack.us/img10/4435/35cubes32hz50sqin6lw.png
which I was going to build, and I noticed that the port wasn't quite as long, so the tuning must be higher.
But I really like the box, looks great. It would be a perfect fit in my trunk, and if the port walls were extended a couple inches the tuning would be what I am looking for also //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
winisd doesnt factor in port displacement for tuning, therefore, the volume that you add into the *Volume* field, is gross, not net. once you factor out the sub/port wall displacement, thats how you get your correct tuning.
=[(32-1.5)*(14.5-1.5)*(22.25-1.5)]/1728=4.76 ft^3 internal volume not factoring in port displacement
=(13*4*25)/1728
Port Displacement
if it uses of the sides of the box for one side of its port wall, then:
(port height) x (port length-wood thickness) x (port width + wood thickness) / 1728
if the ports in the middle of the box, and has its own walls, then:
(port height) x (port length - wood thickness) x [port width + 2(wood thickness)] / 1728
I don't know if I completely understand what you said, but I'm pretty sure you need to enter the net volume in WinISD.
Port Displacement
Yep, my mistake. I think that is why I got slightly different results than when I posetd earlier (because I had done it correctly then).
iamamp3pimp
Bass Heads Entertainment
iamamp3pimp
Tampa FL
nVRuckus
