Project, 16 8's in a Bandpass IB Clamshell...In a Stratus.
Rawr-DQ
!!!!Vote Third Party!!!!
Title says it all right?
I've pre-ordered the subwoofers, I will get them near the end of may/ early june.
This is the stratus:
I will be tearing out the old baffle, and the front.
Making some kind of base, battery rack, and amp rack in the trunk.
Clamshell will go behind the seats, then I will seal the trunk off, stuff it with polyfill.
I bought E8's (sundown)
The final specs will look like this:
Re = 3.37 ohms (4 ohm nominal)
Fs = 34.9 hz
Qes = 0.5323
Qms = 6.93
Qts = 0.4943
Vas = 7.6 L
BL = 13.3 N/A
Mms = 127.7 grams
Cms = 162 um/N
Xmax = 12mm one-way linear (70% BL method)
Rated RMS Power = 200 watts
Depth = 4.25"
OD w/ gasket = 8 5/16"
Cut Out = 7"
Sealed Box:
0.280 ft^3 w/ F3 of 50 Hz (Qtc = 0.707)
Ported Box:
0.60 ft^3 tuned to 30 Hz
F3 of 25 Hz
They should be black instead of chrome.
This will be fun! //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
these will be powered by 1 or two sundown 3000d's
ok, i gotcha, what makes it bandpass though? Thats just IB
it's 2 chambers firing into another camber...the open area on the "face" of the box is considered a chamber...therefor it's a bandpss
TBH, that is too many speakers for just a pair of 10" subs. The Skar 6.5s and tweeters are very efficient and can get super loud on moderate...
993
I purchased a set of 1" stand off rings, should still be good from door to cone as well. They won't fit without the spacers, the recoils I...
30
9K
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
Yes. It's one of those fundamental truths I somehow manage to unlearn every time I figure it out. :rolleyes:
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
Rawr-DQ
Rawr-DQ
Fort Myers, FL Posts:____________31,337,666,999
iamamp3pimp
Decebal
    Jun 10, 2024
