Programming in Perl - Need Some Help
qtipextra
The Original
Im dusting off my brain, trying to write a in Perl.
What I am doing is taking a log file and trying to return just the filename.
A line of the log file looks like this:
Code:
Error: SetupDecompressOrCopyFile() "C:\Documents and Settings\QTIP\Desktop\new\I386\BEEP.SYS" to "C:\UBCD4Win\BartPE\I386\SYSTEM32\DRIVERS\BEEP.SYS" 2: The system cannot find the file specified.
This is the code that I have so far. I am trying to use the split function to return the only the filename (the one listed first)
Code:
system ("cls") ;
open( FILE, 'log.log' ) or die( "Cannot open: $!" );
@log = <FILE> ;
close (FILE) or die ( "Cannot open: $!" );
foreach (@log) { @split = split (/Error:/, $_, 9999) ; }
print @split ;
And right now all this outputs is the last line of the log file, which is this:
Code:
Use the [<<] and [>>] buttons to jump to Error/Warning.
Anyone good with perl help me out?
So I had a DUH moment. I used the function in notepad "find and replace" to clear out all text before the file name, and eliminate "" 2: The system cannot find the file specified." on all lines, so now a line in the log.log looks like this:
Code:
I also forgot to use the push function to add each element back into the array, so I got back each line in the file.
I am, however, still having trouble splitting after the file name. Right now this will display each line in the file, without cutting anything out.
My script so far:
Code:
system ("cls") ;
@log = <FILE> ;
foreach (@log) {
split ( /M#"#/, $_) ;
push (@output, $_)
print @output ;
Any Ideas?
qtipextra
The Original
qtipextra
Idaho Falls, Idaho
qtipextra
