Professional tuned system worth it???
ttran
Texas
I don't have any type of equipment to tune my system and don't really know much about frequencies to do anything myself. Is it worth it to pay someone to do it?
I feel like there is more potential out of my system.
Pioneer 880prs
Phoenix Gold RSd65cs
JL e2150
JL 10w6v2
JL 500/1
just do it by ur own ear. Mess with the EQ's a little to find an area where u like it. No point in gettin it "professionally" tunned when they will probably do the same thing and u will probably not even like the sound. Everyone has their own taste.
I'd say yes and no. Are you running the PG comps active? If running active and totally lost on setting xovers, etc... then yes. If not then you really are only messing with EQ settings & gain, so I'd do it myself.
Other thing is that ideally your setup should be tuned to your ears, not someone elses. Meaning that the only equipment you need is your ears.
Personally I tweak mine every few weeks. For instance I'll bump up the midrange +1 on the HU and listen to it like that for a few days with a variety of music. If I like the new setting it stays, otherwise I'll change it again, but always small increments up or down and a few days to see what I think.
The thing is though, I have no idea what any audio adjustments on my headunit does. i have a 16 band equilizer. I just want to get a good start and maybe the tuner can teach me a little. I also have a bunch of settings on my amps and I really don't know which way to go for a better sound.
Up on down or hz? etc..
there is amp setting tutorial around here somewhere, that would help a little unless you already read it and it didn't help =X
//content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif for viets! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Different companies do the loudness at different levels. The one that you have would probably have sounded pretty good on factory speakers and...
I think this may be more of a home theater thing to just keep them from wanting to vibrate across the room by balancing them out. This may or may...
87
16K
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
396
727
ttran
ttran
Texas
blimblam
    Jun 15, 2024
    Jun 15, 2024
