TKCARAUDIO
Ok I just picked up a 96 Cavilier for a work car. Came with JVC KDG140 head unit, 8 gauge amp kit(walmart) Has a 2000 watt Max 1000 watt RMS Insignia 2 channel amp and a pair of 1000 watt max 500 watt RMS Insignia 12s in a Q-logic ported box... The amp is only about a lil under half on gain and everything else is pretty low... It hits really hard with all the adjustments on head unit maxed out to the neg.... I get it turned up around about half way where its hitting nice and clean after a few mins of play it will cut out like amps goes into protect mode. I turn the volume down 1-2 numbers(example from 15 to 14/13) then it works fine....
They had the RCA Jacks ran with the power wire so I moved it to the opposite side of car...
Also have tried other runs of power wire
The subs are Single Voice Coil and they are 4 ohm just like amp is.
The car has new alt new battery ect... No cap but the lights dont dim at all when using system....
The thing I thought was funny. I pulled the amp from the car when it started doing so and put in my Vette on 2 Planet Audio 12s that are DVC 2 ohm and The amp just slammed no problem. I put in my brothers impala with 4 mtx 8000 12s and no problem didnt cut off at all.
I didnt do bad either way picked the whole car up for under $600 with system/carbon fiber tails and its a 2.2 5 speed with header exhaust all kinds of new parts lol....
Just thought Id see if anyone here knew of what it could be.
The guy told me about when I bought car and I was like ok. I mean its still pretty loud before this so Id like to get it on a meter somewhere locally to see what it does for cheap stuff.
I never heard of insignia car audio before this..... Any opinions on this stuff as well....
I have always only really delt with MTX/Kicker/JL/Audiobahn/Audiopipe the bigger name brands locally lol....
thanks guys Ill try to get some pix of it all up asap for your info
