Problem with stock ground wire G35
  • Thread starter noooorb
  • Replies 0
  • Views 1K
noooorb
nyc
Hey guys so I'm putting back the OEM radio into a 03 G35. I put it back in, connect everything, and find that neither the heater nor the radio controls work (they are sort of integrated) - the lights do not light up either. I was also disconnecting my amp power wire from the battery so I figured that might have blown a fuse or something. I checked the radio and heater fuses under the dash - all are fine. But when I connect the multimeter to see the voltage between power and ground, I get 0 - no power supplied. Now when I connect the ground wire on the multimeter to the chasis, i get the 12v. Is there a common ground somewhere that is disconnected? I looked at the factory service manual and they don't really mention the path of the ground wire...
Thanks in advance fellas
nm.... just made a new ground and it works again
noooorb
noooorb
nyc
noooorb
