Problem with my alpine cda-9855
  • 2
yungunna
Ive been fooling arould with my deck for a while now tweaking it and such. When I lood in the manual under Parametric Eq settings, under the level adjuster for each band (ie: front,rear, and sub) it says adjustable from -6db to +6db by turning the rotary encoder. The problem is when I do this, it goes from -6db to 0db and doesnt go any higher. Is it a setting that needs to be changed or something im doing wrong. Please give me some answers
Nother mind, I figured it out.
I have no experience with that deck but do have expereince with a Pioneer 860. This class of head units usually lock out certain features until you activate a "pro mode" or "3-way" mode. Make sure you arent in the normal mode of your deck, there may be a switch or something on the back like there was with my premier, hope that helps.
I'm hoping to find someone who might be able to repair this head unit. The faceplate doesn't slide out at all.
Love the site, arguments over non-issues, not so much. ;)
13
87
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
831
yungunna
yungunna
Jacksonville, Fl
yungunna
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
