problem with autopage alarm system
spindrift0
i purchase and had installed an autopage alarm system two years ago. it worked great until a month ago when the alarm started going off randomly. there aren't any apparent triggers for the alarm (no big trucks driving by or people near the car). i don't know how to stop it from going off. any suggestions?
do you have a hood pin switch? it is pretty common for these to fail after a couple years. try disconnecting it if you have one.
there should be a section in the manual where it will tell you what zone was triggered by counting the flashes on the LED after you disarm the alarm.
other than that, i would go back to where you had it installed. you will most likely void any warranty you have if you go digging around in the wiring yourself.
spindrift0
spindrift0
San Diego
Duct Tape
