Problem,95 firebird no trunk
theotherguy
I have a 95 pont firebird,it's a hatchback...well sort of. I got a snag here,I have no trunk to fire sub's into. Would faceing sub's up and tward front of car be capble lot's of low bass? Or should they fire off the back window to try and echo like a trunk? Any one got one of these car's what sub's sound good in them?
f bodys are easy..
build the box flush from the rear hatch forward, and into the cavity at the back of the car..
fire woofers and port upward into the glass, position them at the rear of the box
you're done
Loyd L.
Yea point them towards my glass, its so easy to make a fbody loud...
i have one mtx8000 and a old alpine amp pushing maybe 250 watts and it was loud.
Yup. Audioenhancers makes a couple real nice boxes for dual 10's or 12's for the rear well. The biggest box they make for it is 3.00 total cubic feet.
Yup... I've got a Camaro and Firebird... camaro has 2 - 12", Firebird I ordered the box blank with no holes cut... I cut my own hole for a single 15".
Some advice... if you have the means, order the box direct with the baffle board uninstalled (loose)... add some internal bracing, then install the baffle board.
Man, if the enclosure company will do what Gary said, make up your mind as to what you are going to install and go to town.
And as stated before, vehicles without a trunk are not a problem, they are a blessing. Hatches/SUV's are wonderful for audio. //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
what about a convertable fbody like mine??? any idead there? My setup is totally ghetto, i laid the back seat down and threw a 5 cube box with an mt15 in it //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
omg..haha my friend had a camaro we put one DD3512 in about a 3.5 ft enclosure custom built for that trunk with a massive straight port tuned to 40 hz
it was a kick *** setup........amazing infact make sure to face it up towards that back glass. Its so easy to make that car loud. (but soooooooooooooo man rattles in that car)
theotherguy
theotherguy
allegan Mi.
theotherguy
