price for deading
shoot man just do it yourself. order fatmat , raammatt , second skin . i just got 50sq ft of fatmat $60 plus shipping but that's more then enough to do your doors. ok here's what u do
STEPS
1.) pull off the door panel most of the time there just plastic clips/poppers that u can pop out from the actual metal on the door . (CAUTION: Make sure that all screws are taken out first of the door panel)
2.) take out the speaker
3.) clean off the door panel if it has anything on it
4.) get yourself a wooden roller or rubber roller whichever
5.) take each sheet of deadner and slowly roll on the deadner to the door making sure that it is flat and sticking on the door fully
6.) make sure the door is done fully but do the inside of the door first i should of stated that first sry (making sure though the window can roll up and down with no problems.)
7.) put the speaker back in (make sure your connections on the speaker are still good not loose)
8.) put the door panel back in pop the poppers/clips back in
9.) put the screws back in the door
10.) test door panel make sure it's on there correctly
11.) give yourself a pat on the back because u just saved yourself a good amount of cash by doing it yourself:D.
need anymore help man just lmk. Good luck.
What do you drive? Most door panels come off pretty easily and applying the deadener as easy as putting tape on a piece of paper... don't pay someone to do it. It's only a little time consuming but really easy, and no ones time should be worth that much money.
redfish what do u mean seal the doors. i mean there are many way's but no matter what air is always going to get out. but just do the inside of the door and the outer and you will be good like i had listed all those steps for you.
redfish8
Banned
redfish8
us
Rudy
