Prestige 1000wt amp
Basically it's a "don't waste your money on that" situation. How much do you have to spend? And what voice coil configuration is your sub?
Ive had this amp give to me> And all i want is to know can i start this amp out on my L7?
If your L7 has dual 4-ohm voice coils, it'll work fine. L7s are available with dual 2 or dual 4-ohm coils. If it is dual 4-ohm, wire the coils in parallel for a 2-ohm load, and your amp will put out 500wrms to it, which should power it nicely.
If your sub is dual 2-ohm, you would have to wire the coils in series for a 4-ohm load, and your amp would probably only put out 250w to it, half of it's potential. Underpowering the sub won't do any damage, just make sure to set the gains properly, a lot of people with too little power crank their gains trying to get more causing damage.
Thanks man, I appreciate the info. I can finally stop being stressed out over this amp.
I agree with others, just buy the OFC. My last wiring was oversized CCA, and while it still works, and looked okay when I peeled the heat shrink...
127
The umm1 is just a rebadged dayton/minidsp mic. I personally have a umik2 and use a regular usbc-usbc to hook it up to my laptop and a...
152
143
120
apexi5
import racer
apexi5
Chattanooga, TN
Springfield1225
