Prestige 1000wt amp
Basically it's a "don't waste your money on that" situation. How much do you have to spend? And what voice coil configuration is your sub?
Ive had this amp give to me> And all i want is to know can i start this amp out on my L7?
If your L7 has dual 4-ohm voice coils, it'll work fine. L7s are available with dual 2 or dual 4-ohm coils. If it is dual 4-ohm, wire the coils in parallel for a 2-ohm load, and your amp will put out 500wrms to it, which should power it nicely.
If your sub is dual 2-ohm, you would have to wire the coils in series for a 4-ohm load, and your amp would probably only put out 250w to it, half of it's potential. Underpowering the sub won't do any damage, just make sure to set the gains properly, a lot of people with too little power crank their gains trying to get more causing damage.
Thanks man, I appreciate the info. I can finally stop being stressed out over this amp.
This is correct. Those insurance /extended warranty people dont want to pay for anything that isnt listed on the contract, of which to most is...
6
151
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
12
214
The HU us likley 12-15 x 4 at best so yes, using an amp will be hugely beneficial, night and day. The HU us not going to drive a sub to any...
163
https://www.amazon.com/dp/B07DLC9M48/?tag=caraudiocom-20
25
394
apexi5
import racer
apexi5
Chattanooga, TN
Springfield1225
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
