Sold Premier Amp FS
I will take pics tonight - the model is prs x720,
This is the info from pioneers website - this amp is very under rated, it is probably pushing more like 750 watts rms X1 at 4 ohms....
Talk about well-balanced: the 400-Watt PRS-X720 is both a sonic weapon of destruction and a fine musical instrument, capable of reproducing bombshell rock one moment and delicate classical the next. The built-in variable crossover and variable bass boost add to its flexibility, as does its bridgeable 1/2/3-channel capability. Terminals, inputs, and outputs are gold-plated, adding to the sonic purity. The PRS-X720 carries the Premier two-year warranty.
Continuous Power (20Hz-20kHz, 0.04% THD)
2 ch: (4 Ohm) 100Wx2
2 ch: (2 Ohm) 200Wx2
1 ch: (4 Ohm) 400Wx1
Maximum Power (EIAJ)
2 ch: (4 Ohm) 250Wx2
1 ch: (4 Ohm) 750Wx1
Frequency Response: 10Hz - 50kHz (0,-1dB)
Total Harmonic Distortion:
Signal-to-Noise Ratio: >105dB (IHF-A Weighted, at 1kHz)
Dimensions: 10-3/8" x 2-1/2" x 13-5/8"
Features
Bridgeable 1/2/3 Channel Capability
PWM Regulated MOSFET Power Supply
2 Ohm (4 Ohm mono) Optimized MOSFET Output Section
Balanced Isolator Input Circuit
Oversized Gold-Plated Screw-Type Power/Ground Terminals
Gold-Plated Screw-Type Speaker Terminals
Gold-Plated RCA Inputs
Gold-Plated RCA Outputs (Full Range)
Hi-Volt Input Level Control (400mV-6.5V)
Variable Crossover: 50-120Hz, -12dB/oct. (LPF/HPF)
Variable Bass Boost (40-120Hz, 0 to +18dB)
Subsonic Filter (15Hz, -18dB/Oct.)
Premier Power Certification Sheet
Premier Two-Year Warranty
slOw Z Rally
slOw Z Rally
Detroit, MI
slOw Z Rally
michigan born
    May 14, 2026
michigan born
    May 14, 2026
