Precision Power P900.5 5-channel small Class D
trumpet
Barry Schanz
4 in stock
NIB
Power Ratings:
  • RMS Power 4 Ohms(14.4V) 70W x 4 + 270W x 1
  • RMS Power 2 Ohms(14.4V) 115W x 4 + 440W x 1
  • RMS Power 4 Ohms Bridged(14.4V) 230W x 2 + 440W x 1(2 Ohms)
  • RMS Power 4 Ohms(12.0V) 50W x 4 + 185W x 1
  • RMS Power 2 Ohms(12.0V) 80W x 4 + 300W x 1
  • RMS Power 4 Ohms Bridged(12.0V) 160W x 2
Additional Technical Specifications:
  • Class D Full Range SMT Circuitry
  • Double Sided Composite Epoxy PCB
  • 102 dB Signal-to-Noise Ratio
  • 110 Damping Factor
  • 32 dB Stereo Channel Separation
  • 200 mV – 6V Input Sensitivity
  • Input Impedance 3.3k Ohm
  • 50-4kHz 12 dB High Pass Crossover – Front
  • 50-4kHz 12 dB High Pass Crossover – Rear
  • 250-4kHz 12 dB Low Pass Crossover – Rear
  • 45-450Hz 12 dB Low Pass Crossover – SUB
  • Subsonic Crossover – 10-50 Hz
  • Bass Boost – 45 Hz, 0dB – 12dB
  • Source Input Selector
  • Three-Way Protection Circuitry
  • Delayed On/Off Circuit
  • Tri-Mode Capable
  • Band-Pass Crossovers
  • Direct Wire 8ga. Speaker Terminals
  • Direct Wire 4ga. Power Terminals
  • 0ga Reducer Terminal Included
  • Remote Bass Knob Included
Dimensions:
6.5″ W x 13.25″ L x 2″ H
Need a wiring kit? RCAs? Head unit? Dash kit? Speakers? I can get all types of product for your installation needs.
Easy Way Electronics, Inc.Store
$259 shipped
Free shipping to the Continental US
A QUOTE is required for all other locations.
My i-Trader feedback for caraudio.com - absolutely stellar record
do you have any other 5 channel amps that are a tad more powerful? lets say 75wx4@4ohm +600x1@2ohm or 1ohm?
I have the JBL GTO-5EZ. 50W x 4 @ 4 ohms and 350W x 1 @ 4 ohms, 75W x 4 @ 2 ohms, 500W x 1 @ 2 ohms. The Massive Audio NX5 is rated at 120 x 4 @ 4 ohms and 400W x 1 @ 2 ohms. They rate it for 1 ohm sub operation, but due to complaints of this model overheating I don't recommend using it below 2 ohms.
The other 5-channel amps I can offer are less powerful.
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
437
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
342
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
SlugButter
    May 4, 2024
slater
    May 2, 2024
