Precision Power P900.4 145W x 4, 4 available
trumpet
Barry Schanz
Precision Power Phantom P900.4 Class D Full Range 4 Channel Amplifier
Power Ratings:
RMS Power 4 Ohms(14.4V) 145W x 4
RMS Power 2 Ohms(14.4V) 225W x 4
RMS Power 4 Ohms Bridged(14.4V) 450W x 2
RMS Power 4 Ohms(12.0V) 100W x 4
RMS Power 2 Ohms(12.0V) 150W x 4
RMS Power 4 Ohms Bridged(12.0V) 300W x 2
Additional Technical Specifications:
Class D Full Range SMT Circuitry
Double Sided Composite Epoxy PCB
102 dB Signal-to-Noise Ratio
114 Damping Factor
32 dB Stereo Channel Separation
200 mV – 6V Input Sensitivity
Input Impedance 3.3k Ohm
20-4kHz 12 dB High Pass Crossover
50-5kHz 12 dB Low Pass Crossover
Source Input Selector
Three-Way Protection Circuitry
Delayed On/Off Circuit
Tri-Mode Capable
Band-Pass Crossovers
Direct Wire 8ga. Power & Speaker Terminals
0ga Reducer Terminal Included
Dimensions:
6.5″ W x 9.5″ L x 2″ H
NIB
ships free by UPS Ground
Fedex and USPS available upon request
on hand now, no waiting list or "sorry, we don't have this in stock" e-mail after you've already paid for it
I run this amp on my midbasses and mids and it is very efficient, very very low noise floor, tons of power, no turn on pops, and very small.
bump
I can now order the Massive Audio Nano Bit amps for another option for an even smaller full range Class D amplifier. B2 mono, BX2 120W x 2, and BX4 120W x 4
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
474
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
698
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
    Jun 1, 2024
    May 31, 2024
