Precision Power P600.2 190W x 2 600W x 1
trumpet
Barry Schanz
Precision Power Phantom P600.2
4 for sale
NIB
This is a little beast of an amp. If you want to beat up a pair of components with a lot of clean power this is the amp to do it. It will also do quite well bridged to a 4 Ohm subwoofer.
Power Ratings:
RMS Power 4 Ohms(14.4V) 190 x 2
RMS Power 2 Ohms(14.4V) 300 x 2
RMS Power 4 Ohms Bridged(14.4V) 600 x 1
Additional Technical Specifications:
Class D Full Range SMT Circuitry
Double Sided Composite Epoxy PCB
2-Ohm Stereo, 4-Ohm Bridged Multi-Channel
Three-Way Protection Circuitry
Delayed On/Off Circuit
Tri-Mode Capable (2/4/5 ch. models)
Variable 12dB High, Low, & Subsonic Crossovers
Direct Wire 8ga. Power & Speaker Terminals
0ga Reducer Terminal Included
Dimensions:
6.5″ W x 6.125″ L x 2″ H
$160 shipped
Free ground shipping to the Continental US(estimated value $20)
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
417
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
325
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
