vario
digidash hit the gas...
Decided to reinstall my two subs and two mono block amps (one per sub) I use a Y splitter on each channel rca. The problem is I have to have the gain knobs cranked really high to get the necessary 30 volts on each amp. This is causing a lot of distortion and it makes the amps overly hot.
Should I run a preamp line driver right in front of the y splitters? I want something that presents as flat a signal as possible with no worthless bass boost or anything.
