PPIguy's 1995 Acura Integra GSR setup
PPIguy
This a downsized setup from what I've had in the past. The Integra is my performance ride so I decided to drop the weight of the stereo system, went with a single 6 channel amp to run everything, and a single 10 inch sub.
Head Unit: Alpine 7894
Amplifier: Precision Power PC650
EQ: Precision Power EQ31
Fronts: MB Quart PSD 213
Rears: MB Quart RKC 116
Sub: JL Audio 10w3v2
Head Unit:
Amp/EQ/rack:
Subwoofer:
More detailed step by step pics later.
Very clean and straight forward, excellent setup.....I love single foot print installs:thumbsup://content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif:thumbsup:
very clean i love that gen of integras what have you done to it performance wise
That could be a whole nother massive thread. But it's a black/black hatchback, all motor build:
Engine:
-Comptech Icebox and short ram intake
-Spoon Sports cams and cam gears
-OEM ITR valvesprings, Portflow inner valvesprings
-Wiseco high compression pistons, 0.5mm overbore, 12.0:1 CR
-Hytech header, high flow cat, and exhaust
-Chipped ECU
-Exedy clutch
Suspension/Brakes:
-Koni yellow shocks
-Eibach Pro Kit springs
-Suspension Techniques 19mm rear sway bar
-Cryogenically treated Powerslot rotors
-Hawk HPS brake pads
-SSR Integral 16 inch rims
-Yokohama S drive 205/45 tires
Cosmetics:
-NR Auto white face guages/PIAA super white cluster bulbs
-all amber corners
-'98-'01 style taillights and rear bumper
-no VTEC badge
-shaved rear washer nozzle
Rolling sleeper status! Dyno'd at 183whp/133wtq before I got the Hytech H/C/E system.
Front speaker install:
MB Quart PSD 213 component set with 5.25 inch mids.
I built plates out of 1/4 inch MDF, then painted them with Kilz to keep the wood from soaking in water and expanding/growing mold. Water manages to get to the back of the door speakers somehow.
Crossovers are mounted on the backside of the panel to the right of the sub box.
I used some Dynamat Premium inside the doors and on the door panels.
Rear speakers:
MB Quart RKC 116, 6.5 inch coaxial with suspended tweeter. They have a small separate passive crossover, the rectangular black box zip tied to the split loom to the lower left of the speaker.
Blove1991: Never been into the idea of building a fiberglass sub enclosure. It's too messy and toxic, heh.
PPIguy
PPIguy
New Hampshire
PPIguy
