PPI BK340.4 - Can this amp run an active setup?
HoovaDeuce 82
I'm in the market for my front stage and amps right now. I found this PPI BK340.4 and it goes for an easy $150. It does 55x4 rms at 4 ohms and I plan on running an active setup so I need a capable 4 channel amp to do this . This amp does have the crossover settings I just wanna double check before I start planning to make any purchases. Here is a pic of the amp's settings.
http://www.precisionpower.com/html-version/images/BK340-4/2L.jpg
Sweet! I think I have found the amp and If this is the amp I go with I will hit you up. I will not be buying until the Friday after next though. Hopefully by then I also know what tweets and mids I want though I have an idea. Thx
Yes this amp is active, I use to own it and ran a active 3 way setup on it. Great budget amp IMO
HoovaDeuce 82
HoovaDeuce 82
Ft.Worth, TX
BigSix
