DVC subs ARE made to run on coil or both coils.
1 set for 4ohm
both for 2ohm
red to black and over for 8.
and I understand that the rms is halved if your using one coil but your amplifier is also putting out less but that has no effect on the setup because it cancels itself out, each coild will get 500rms weither ran @ 2ohm or 1 ohm.
I UNDERSTAND THAT. but you gotta think 1000rms on the same driver in the same box will runner hotter than 500, even if each indivudal coil is getting the same load.
Cliffs:
subs still work
amp doesnt.
