Powering up a HU
  • 6
Sure there is.
U need to have one of the following
a car battery
or
a AC to 12V DC power converter
or
A computer powersupply with atleast 10amps on the 12 volt rail
Then you just hook up 3 maby 4 wires.
Ignition wire.
Constant power
Ground
sometimes illumination
yep just hook up the constant wire (yellow) and ground to your bar battery and you can power it up or u can get a $20 ac to dc converter from radioshack. i have one they always comeint handy at some point of time.
U also need to hook up the ignition wire or it wont turn on.
If your deck has the illumanation wire you will need to hook that up also or no display for you.
U also need to hook up the ignition wire or it wont turn on.If your deck has the illumanation wire you will need to hook that up also or no display for you.
Not true. Neither the illumination, nor the the dimmer wire are connected on my 880. Works fine.
okay so the yellow/black wire connects directly to the batt.
but where do i hook the ignition wire up to?
MY 680 needed that wire hooked up but some dont. that is why I said sometimes.
you should just need to touch the red (or maybe its yellow) and black wire to the 12v battery under the hood of your car/truck
You need both the constant and ingition wire
thanks for the tip, i tried it a few days ago when i had some spare time...
i hooked up the ground to the - terminal and the power and accessory(red wire) to the + terminal on my car battery and the HU powered up with no problems
10
714
My experience says that for most people, usually, overpowering subs doesn't really gain much, especially for daily or music. Actual power levels...
800
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
When you say power on for a limited time, do you mean power after the vehicle has been shut off or just turning on the radio and it plays for a...
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
champaned_out
champaned_out
SoCal
champaned_out
    May 31, 2024
    May 24, 2024
