Powering my system.
DrumnBass
New 3000GT-Need....Camera
I will be running:
2x AQ HDC315 subs running on,
1x AQ2200D amp per sub
1x AQG 6.5 Component Set (2x AQG-6.5", 2x AQG-T28, 2x AQG-X02)
That's what I have the money for at the moment. If I keep my stock battery, will I need more than 1 Kinetics 2400 in the back? or should the stock batt and the 2400 be able to hold it without dimming/voltage dropping w/ this setup and a Big 3 done?
Just wondering because I'm sort of tight on money for the time being, but I dont want to install all this and my batteries not be able to power it.
what kind of draw does the amp pull
Not too sure, i didn't get manuals but im looking on the AudioQue site now...
Here's all the specs:
Digital Monoblock 1 ohm stable
Input Sensitivity***********************0.2v-8v
Variable Low Pass Filter ****************20Hz-200Hz @ 24dB/Oct
Subsonic Filter************************10Hz-50Hz @ 24dB/Oct
Output Master / Input Slave, 2 amps linkable connection
Remote Level Control*******************n/a
Clipping Display Led********************n/a
Signal to Noise Ratio*******************90dB
External Fuse Rating*******************200 Amps, 400 Amps Linked
Tested Voltage and THD****************14.4V & 1% THD
4 ohm power************************740 x 1
2 ohm power************************1300 x 1
1 ohm power************************2200 x 1
1 ohm Power @ 16V @ 1% THD**********2500 x 1
1 ohm Power @ 16V @ 10% THD*********3400 x 1
2 ohm Linked Power @ 14.4V @ 1% THD***4400 x 1
Dimensions**************************17.71"(L)x9.27"(W)x2.35"(H)
That's all the information the site gives... Hope it helps.
to be on the safe side, I wouldn't run both amps until I got another battery... 200 amps @ 14.4 rating, so you're looking at probably around 13.9-14.0 volts on your stock with big three and kinetic, and with the voltage drops, it'll pull more amperage so don't risk you're amps by half doing it.
Ok... thanks man //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
DrumnBass
DrumnBass
In A Mixtape
DrumnBass
