C o l i n
Hoping someone can point me in the right direction, although usually I'm looking for something that's just too good to be true, lol.
Here's what needs to be powered:
1) Pair of CDT CL6 (forget the exact model) components located in my front doors, they are old but still in great condition. iirc power handling is 150w rms (I'll need to double check the box when I get home)
2) Image Dynamics IDQ10v2 D2 power handling is 250w rms / 500 peak
I don't want any audio equip in the trunk ('04 Impreza TS Wagon) so the sub is going under the passenger seat in a RAAM Audio box. I need my amp to fit under the driver's seat, so it has to be pretty small. I already have an amp which is capable of powering the components OR the woofer but not both. Currently the components are running off of head unit power (Alpine CDA-9857) so anything will be an upgrade really.
I'd like to keep the cost of the amp under $300, even better if it's under $200, and I don't mind buying used.
The amp that got me started thinking about this is the Alpine PDX-4.100, it seems like it'd do pretty much exactly what I need (although still underpower the components a bit). Also just stumbled across an MA Audio HK598 which has even more power but I haven't seen recommended as often as the Alpine (plus it might be too large, I need to measure under my seat). Anyone have any input on these or other amps that fit within my parameters?
Thanks in advance!
-colin
Thanks in advance!
-colin
