Powerbass XA-1500d
matt_martin87
OG
Powerbass XA-1500d
Works perfectly. Does not come with bass knob.
Specs:
RMS Power: 500W x 1 @ 4 ohm
RMS Power: 1000W x 1 @ 2 ohm
RMS Power: 1500W x 1 @ 1 ohm
Strapped Power: 2500W
Oversized Power and Ground Outputs - 4 Gauge CNC machined high effeiciency connection for max power transfer
4-Way Protection Circuitry
Total Harmonic Distortion:
Frequency Response: 10Hz - 400Hz
S/N Ratio: >90 dB/W/M
Damping Factor: >200
Input Sensitivity: 0.3 - 8.0 volts
Crossover Slope: 24 dB
Crossover is fully adjustable from 40 - 500 HZ + there is an additional subsonic filter
High-Pass Crossover Freq: 50Hz - 250Hz
Variable Subwoofer EQ: 0/+18 dB
Subwoofer EQ Frequency: 45Hz
Fuse Rating: 120A (3x40A fuses)
Dimensions:
14.17" x 10.51" x 2.56"
360mm x 267mm x 65mm
$150 shipped
Ships Fedex unless you have another preference.
matt_martin87
OG
matt_martin87
Beatrice, NE
matt_martin87
    May 24, 2024
