Power wire help (Please fast)
how do you buy from that site??? im confused. step by step please cause it says its per feet coorect and im not sure how many feet to get. then it asks for quanity but i only need one.... ahhhh help.
do i have to put the 1 foot pieces together cause im not good at that kind of stuff. help please....
Lol, you put in for quantity however many feet you want, they cut it to that amount and then send it to you...//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif .
boy im a **** lol does it matter what color. and how about the terminal to put on the battery post...
red holds more power...
//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif jk, color doesnt matter if you can remember which wire is which
back on this topic again...
so heres how my wires will look correct
battery>in line fuse 300a>amp
the problem i see here is that the 1/0 gauge wire doesnt look like it will fit in the power terminal...
now i was thinking something like this would work battery>in line fuse> distro block> then 4 gauge out to amp... with 150 watt amp in block.....
now would that work cause seems to me that if it blew before when using it directly to the battery whats going to stop it from blowing at the distro block?
In the event where the powerwire doesn't fit in the terminals. Look into getting reducers.
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1557388/vpcsid/0/SFV/30046
ok reducers... now how do those work?
also when i do upgrade the wire to 1/0 gauge and put the 300 a fuse inline and run it to the amp using this reducer thing... will i need to upgrade the fuse in the amp itself?
darkdrake27
darkdrake27
ky
darkdrake
