power hungry bp1200 and eclipse subs
  • 2
cyber256
I have 2 eclipse 88120 DVC subs in a sealed box powered by a JBL BP1200 running at 1 ohm (i think...i have the pos of both coils on both subs going to the pos amp out on one side [left channel] and the negs of both coils on both subs going to the neg amp out on the other side [right channel]...these subs are 4 ohm DVC so that should be 1 ohm impedance right?) I have a dodge neon so i knew that i would need a bigger alt so i bought a 135 amp alternator. Well even during the day with no headlights on or anything the HU still dims when the bass hits and i don't have the gain on the amp set above half. The bass boost is only at about 1 and the low pass is set to about 40. So i'm wondering what do i need now? I was thinking about a 2 farad cap but i've heard ppl say that they don't really help and are just a bigger burden on the alt. And i've heard that a deep cycle battery is an option but then don't you need to hook the alt to it in order to keep charged? Thanks for your help
Are you running any other amps ? Just the one shouldn't be a problem. In your case a capacitor probably would help your problem. You should have enough juice coming from the alt not worry. The reason myself and others say cap's are just a band aid solution. Is because if you have severe electrical problems. Adding things such as extra batteries, or capacitors. Puts more stress on the alternator. The extra batteries and cap's need to be charged too. So IMHO the cap sounds like a good choice. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I sure did. Nostalgia is what brought me to this website, wondering if it still existed. I can still name some of the people and describe some of...
8
214
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
561
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
419
cyber256
cyber256
Frozen Tundra
ramos
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
