power effieceny of amplifiers
Dragonknell
Computers B4 I Could Read
I did'nt even think about this before, what exactly is the power efficeny of an amplifier? if its rated at 800 watts rms, its that output or how much it uses? if it has specs posted at 800, and pulls 800, and has 90% efficieny wouldnt it be closer to high 600s rms? or does it drawl 1000 and output 800?
Of course it could have 100% effieceny, but seeing as amps get pretty hot it isnt likely.
depends on its design.
Class A is quite inefficent(like around 30-40% I believe)
Class AB is a little better (around 50-65%)
Class D is great (75-85% maybe higher)
and in your example, the amplifier pulls 1000(they don't pull power, they draw current btw), and output (source current) 800.
sorry for the errors (current), so im going to be very pressed on power/current; having a 90amp alternator, and a stock batter; with a 800 watt rms class d amp (either a8000t or Hifonics Brutus, depending on ampere drawl or efficeny) and a 150 dc to dc 90% effieceny power supply.
That means that with both of those running, not including my normal car stuff... that my battery will be constantly draining ?
So should i be watching power ouput as in watts
or
overall ampere drawl?
watching amps with everything on in my car including ac full blast im guessin at 35 amps, the hifonics brutus is like 40 amps? and the power supply unit is 150 watts so nominal
But 800 watts rms and 150 watts rms not including car standards
could somoene explain this
i figured that lol //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif it'd sell better
or
Take about 15% off all those efficiencies and you are more in the ballpark.
Figured I was off a bit, in theory that is the effiecencies of the designs, but you know how far theory gets us sometimes //content.invisioncic.com/y282845/emoticons/spank.gif.0d78e34d42ea8780359e903aeb6697d6.gif
then the 40 amps on the brutus is underrated?
Read my thread.
"Using the formulas above even at 100% efficiency I don’t see how the Hifonics can output 1000W RMS if can’t draw more than 60amps."
Answer
"That amp use slow blow fuses. The fuses can take twice their rated current draw for a few minutes of constant power draw."
so then this hifonics brutus will be pulling over 1200 watts. and outputing 800 watts rms. Basicly im going to need a new alternator... ghay.
Even with a farad cap... and a new batt...
so then this hifonics brutus will be pulling over 1200 watts. and outputing 800 watts rms. Basicly im going to need a new alternator... ghay. Even with a farad cap... and a new batt...
It will pull current (amps) and output watts.
With one 1000W amp and a 90A alt you should be OK as long as you don't sit at stop lights with it on full blast. May want to upgrade/replace you battery if it has some age as a good battery can help prevent a lot of problems.
I myself purchased a yellow top and will be using my factory (original) 90A alt to power a 1000W Sub amp and 150W highs amp.
Dragonknell
Dragonknell
Detroit
squeak9798
